I decided to get a Nest 3rd Gen (Learning Thermostat) after reading the forums on here. I'm in a rental property with no thermostat and I want to save money on heating, and I figured I could probably take this with me if I move (I also like tech).
I read this forum https://www.diynot.com/diy/threads/upgrading-lp522-to-nest-wiring-diagram.502626/ - and found it really useful and how is easy it was.
The wiring in my LP522 is missing a wire from the CH. But I still went ahead.
I wired it up as per the above post with the missing CH wire.
The HW didn't work on the Nest, which was a surprise. So I just took a wire off, and it now works fine. It was great to have hot water in the morning without getting out of bed and pressing a button. However, my CH wasn't working on the scheduler, or the dial.
This was my final wiring.
LP522 N - Nest N
LP522 L - Nest L
LP522 1 - Nest 4 (green/yellow) ** I disconnected this and reset the HW worked **
LP522 2 - Nest 1
LP522 3 - Nest 6 (white)
LP522 4 - Nest 3 (yellow)
LP522 L - Nest 2 and 5
It's not a total disaster, as pressing the manual button does work - but that doesn't make sense as clearly it can and does operate the CH.
Has anyone else experienced this, and what important are the missing wires?
Rebecca
LP522 N - Nest N
LP522 L - Nest L
LP522 2 - Nest 1
![20191202_073754.jpg 20191202_073754.jpg](https://cdn.diynot.com/data/attachments/178/178353-96e06b70e49487e4a28f79b10c6cb582.jpg)
![20191206_144125.jpg 20191206_144125.jpg](https://cdn.diynot.com/data/attachments/178/178354-821dcbe442c49f66e7a8556cc2f48677.jpg)
Rebecca
