- Joined
- 14 Jul 2023
- Messages
- 4
- Reaction score
- 0
- Country
Hi all,
I'm looking to install an outside tap on our small outbuilding. I've done a bit of DIY plumbing but am no expert! There's already a washing machine out there, so there's a copper pipe coming from the kitchen terminating in an isolator that the washing machine hose screws into. I want to add a tee to feed both the washing machine and the outside tap.
My conclusion is that the best approach is to remove the existing isolator (pic attached) and replace with an appliance tee, then run 15mm JG pipe with a standalone with a double check valve and isolator to an elbow connector onto hoseplate union onto the new tap. Requirement for pipe inserts noted.
Does that sound viable? Also, because of the way the existing pipe runs the check valve will be lower than the tap which will allow me to isolate and drain during the winter.
