Cistern flush valve suspect
12 Feb 2015
Surrey
I am looking at a new concealed cistern. The provided flush valve seems to have a small bit cut off at the bottom, leaving only 3 mm for the rubber washer to make a good seal. I do not understand why they did this, but a leak there would be impossible to repair once the bathroom is tiled.
I understand there is hardly any water pressure but at the same time flashing the cistern with the lever shakes the whole assembly and a weak seal might leak.
Why have they done that?
even if tiled over you must make it accessible.
