Hello,
I am in the process of rebuilding my fireplace and installing a gas fire. I have someone coming to properly fit all the gas pipes but hade a question on the routing of the supply pipe. There is currently the chrome pipe sticking up to the right of the hearth ready for an over the hearth connection, but I am keen to try and conceal the pipe.
I have managed to route an 8mm pipe from the front of the fire, under the hearth, under the floor boards and into the same area as the current supply. I have sleeved the 8mm pipe into 10mm sleaving and plan to cement it down and seal the sleeving to the pipe with fire retardant sealer.
As you can see from the picture the pipe comes up right next to the fire. However what I want to check is I am about to put on the cast iron surround and also the fireplace "legs" which will sit over the area of the pipe. I dont want to fully fix everything to the wall and start filling behind until I know that having the supply concealed in this way is legal. Once I have put everything on top, it will be nigh on impossible to take it out.
Can anyone tell me if it is ok to have the pipe routed in this way?
Cheers
[/url]
Cheers
![](http://C:\Documents and Settings\ajack\Desktop\fireplace.bmp[img])
