B
Bamber gaspipe
namsag said:An why ****
If you are an installer you wouldn`t ask me that question
lcgs said:Sure i was taught way back that the following general rules apply for sizing heating runs: 28mm will take/pass/provide 80.000btu's, 22mm = 40,000btu's and 15mm=20,000btu's.
These figures are laid down somwhere but off hand cant remember where could be a CIBSE book, i think.
Lee
namsag said:Simple answer to the question is, No it should not be piped in just 15mm it should be piped mainly in 22mm with say max of 3 rads on 15mm drops/legs
Typical Tony, don`t know what the F**ck is going on & spouts mathematics, He is as always right though.Agile said:All those old books were based on a diff temp of 11° C.
With a typical condensing diff of 20° c the same size pipes can carry up to double the power.
Tony
Bamber gaspipe said:Typical Tony, don`t know what the F**ck is going on & spouts mathematics, He is as always right though.Agile said:All those old books were based on a diff temp of 11° C.
Tony
Tell me how you install your boilers to give a return temperature of between 56 & 58 Degrees to ensure the boiler condensates properly?
Bamber gaspipe said:nickso said:there are tables you can use to work it out
Where?
Steve__M said:Bamber gaspipe said:nickso said:there are tables you can use to work it out
Where?
http://www.cda.org.uk/Megab2/build/pub-150-copper-tubes-in-domestic-heating-systems.pdf
It's a bit complicated though.
corgiman said:spotting you taking the mick is like trying to spot a bacon sarnie at a bar mitzvah chap
