GavFre said:Is it correct that 65amps is the highest i can go on a 13amp socket?
GavFre said:the warning on the box stated to only take it to 65 amps on a 13 amp plug.
Probably if the instructions say so.GavFre said:Damn, ok thanks.
GavFre said:The max input of the welder is 160 amps i think.
Steve said:As John says, the answer is on the rating plate on the welder. It should say something like "230V ~50Hz ***Amp ***Kw" Where *** is the numbers we need. Its likely to be around 20-30 amps.
breezer said:GavFre said:Is it correct that 65amps is the highest i can go on a 13amp socket?
GavFre said:is there a risk of any damage if i push it slightly higher?
Dont give him ideas!securespark said:GavFre said:is there a risk of any damage if i push it slightly higher?
Blow the fuse?
