- Joined
- 22 Jan 2007
- Messages
- 8,317
- Reaction score
- 4,143
- Country
Hey all, have a titan 2 stroke multi tool hedge/chain saw/brush cutter tool from screwfix a few years ago.
Lines and purge bulbe were worn away and leaking so replaced them.
On using the bulb the fuel runs through the carb fine, starts no problem, and will idle away no issue.
On throttling it it revs up and dies. Will keep doing same every time. Use the bulbs to.move some fuel through it, and it will rev up fine for 15 sec or so then die again.
Have checked and ran with air and fuel filter removed same issue. New fuel, mix checked, lines purged all good, but problem remains.
Which I guess only leaves an issue with the carb? It's like it's not drawing fuel up through the line fast enough on full throttle.
How does a 2 stroke draw fuel in? Anything else I should try before giving up?
