Thanks. The battery makes a big difference (making it functionally more like a pneumatic one).
If I understand the instructions correctly. what they are describing as 2-way switching would probably not be what you want. It would involve replacing both upstairs and downstairs switches with those time-lag switches. You would then be able to initiate a timed period of lights 'on' by pressing either, but I don't think that you could turn off the light from either of those switches during the timed period and nor do I think could you turn the light on 'permanently' (i.e. not timed).
However, again assuming I understand correctly, I think you could probably do as I was suggesting. Assuming you currently have conventional 2-way switching, I think if you kept the two existing switches and connected the lag-switch's 2 terminals to the L1 and L2 (not COM) of one of the existing switches, then it would probably work as I previously suggested - switching on the light for the timed period and then 'off' (provided that the light was switched 'off' by the conventional switches). The two existing switches would then continue to work as normal (except when 'over-ridden' during the timed period after pressing the time-lag switch's button).
I'll be interested to hear what others think about this idea.
Kind Regards, John
