3 Bar twin pump for shower
Lar
28 Feb 2007
Can i run 2 shower's from the same 3 bar pump . Where is best location for the pump . Do i need a special flange for hot water connection . Is a 30 Gallon inderict cylinder adequate for supply for 2 pumped showers. Any tips on installation would be appreciated . ;) ie pipe size ?
Yes you can, but certain criteria needs to met. The cold water storage tanks need to be large enough to cope with the demand. Either replace with a larger one or stick another next to the existing and link together. The feed from the CW storage to the pump will need to be unique tapped in feed and run in 22mm. The feed from the CW tank to the HW cylinder often needs to be 28mm, and the tapping from the HW cylinder to the pump should really be a 22mm no stop sussex flange.
