I need to have 4 zones in a large property
Does anyone know if these exist? I need ideally 5 but a plumber said he knows a 4 zone exists.
If all you want is a programmer, I'd take a punt for the Heatmiser TM4-TS. There is also a wireless model of some sort, but no doubt it'll be significantly more expensive and much less reliable.
One thing worth noting is that the TM4 will NOT control mid-position valves, as there is only one Normally Open contact output per channel. If you have 2-port valves then no problem, and I expect this should be the case as you have so many zones. If you buy the add-on wiring centre then this will give you more flexibility in terms of wiring and connecting of thermostats and the like, but I don't think it's strictly necessary.
true but you can make it work with a mid-position valve if you use a changeover relay
Matt
A "progstat" is a programmable thermostat.I need to have 4 zones in a large property. So I need 5 incl HW but was under the impression 5 is not available on a programmer, only this amount is doable with manifolds.
How will you provide the obligatory interlock (turns the boiler off when rooms are up to temperature).?All rads have TRV's
1. Do you want time and temperature control in each heating zone?
2. Do you want the times to be centrally controlled?
3. Do you want the temperatures to be centrally controlled?
All rads have TRV's
Sorry, but that does not comply with the requirement to have an interlock. The installation would not get the necessary approval.1. Do you want time and temperature control in each heating zone?
Only time, temp will be dictated by TRV's
Yes
No
Doesn't the boiler switch off when water is staying at required temp ie. if all TRV's switch off as reached temp, then water in system stays hotter longer so boiler is off more?
the water in the boiler will continue to heat up until the boiler thermostat turns the boiler off
