At the top of our stairs we have 2 light fittings on the landing ceiling, these are controlled by 2 light switches: one at the top of the stairs, one at the bottom. The 2 way switching turns both lights on or both lights off as you'd expect. No issues here.
I need to add a third light fitting that will switch on and off at the same time as the existing two light fittings. Is it as simple as wiring the new light fitting to the switched-live terminal, neutral and earth terminals on one of the existing light fittings?
Thanks in advance.
Thanks in advance.
