Is it possible to add more mcbs to the 16 way mk board? Currently every way is taken but the bus bar has capacity - is there a cut out on the cover to allow more breakers to be fitted?[/img]
If an RCD is fitted.An expensive option could be to remove an rcd and fit rcbos and new bus bar.
Are you saying that there are spare 'ways' which would allow you to fit additional MCBs if the cover were off, but that you then wouldn't be able to put the cover back because there would be bits of plastic in the way?Is it possible to add more mcbs to the 16 way mk board? Currently every way is taken but the bus bar has capacity - is there a cut out on the cover to allow more breakers to be fitted?[/img]
16 modules or outgoing ways? There's room for 16 standard 18mm modules in there, but 6 are filled with the main switch and 2x RCDs. That leaves you with 10 outgoing ways.Says it's 10 way, but the box says 16
this document. This shows your board and the inside.
What I think you're looking at is the din rail at the back. This just holds the breakers in situ, it is not the busbar,
