Hi again folks,
Advice appreciated on this problem. Apologies in advance for length of post, and if it is in incorrect forum, but I reckon I needed the advice of a central heating expert, although the job may be more of a carpentry one.
I have a Baxi 50 OF boiler sited in the corner of my utility room, which itself is off the kitchen, basically in the rear half of the garage.
The idea is to box in this boiler, and kit the room out with some units etc, just to make it a bit more user friendly.
I need advice on the construction of something suitable to cover the boiler. Ideally I'd like the boiler itself and the flue covered somehow.
I have read on the baxi site (where I downloaded user guidelines), that it specifies that I must have at least 5mm gap at front of boiler, during operation and 400mm for servicing. Thus I propose to build a frame with no less than 5mm gap, with either a door or a panel with simple catches which could be removed in its entirety to allow for servicing. Once removed the door/panel would give at least the required 400mm gap.
This frame would extend to the wall to the left of the boiler (see pic). If this idea all seems in order so far, how would I vent such a space? I have read that I would need high and low vents of 176cm2 and 353cm2 respectively, but exactly what is classed as high and low? For example, is 'low' near the bottom of boiler and high, level with the top of boiler? Or should I extend cupboard/frame/door right up to ceiling, thus encassing the whole boiler and flue, and therefore the top vent near to the ceiling? Also, are there any specific regs/guidlines about what the construction materials should be, or is mdf and the like ok?
As you can see I'm somewhat confused about how to proceed, in fact, possibly best thing I can do is post the pictures and hope that one of you more knowlegable folks will suggest something, in tems of construction/materials and venting requirements.
Thanks to anyone who managed to reach the each of this post, and stay awake, and big thanks in advance to anyone who has any idea on how and what to build!
Quick idea of something I was thinking of :-
Cheers all![Big Grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
![utility11.jpg](http://www.sfhclan.co.uk/images/utility11.jpg)
![utility21.jpg](http://www.sfhclan.co.uk/images/utility21.jpg)
![utility31.jpg](http://www.sfhclan.co.uk/images/utility31.jpg)
![utilityexample.jpg](http://www.sfhclan.co.uk/images/utilityexample.jpg)
Cheers all
