I'm seeking quotes to supply and install a 40cm wide radiator into an existing gas central heating system. the radiator would be installed to the left of an internal door, pipes would be routed around the door (up over down) and connected into the system at the combi boiler that is located at the right side of the door.
I've been quoted £275 for the works, £175 for materials, £100 for labour. this seems a bit high to me. obviously I don't know all the parts required but a quick look on Screwfix and I'm wondering if the £175 is justified:
£16: Kudox Premium Type 11 Radiator 40cm wide x 60cm high
£30: 5 x 3m 15mm copper pipe (I've estimated this, each 3m is £6)
£12: Drayton TRV & Lockshield
£10: End Feeds
£68: TOTAL
in the engineers defense I think he mentioned opting for a 35cm wide x 70cm high double panel radiator that is 'more expensive and special order' and obviously I don't know what quality of materials he's quoting for or any additional parts over and above those I've listed. even though, based on Screwfix prices for materials, surely it can't be any more than circa £100? I can't comment on labour as I don't know how long the job will take and all the tasks involved, so if £100 is fair for the labour I'm estimating the job shouldn't be more than £200.
what do you think? pic of area, the door is just visible on the left, the radiator will be fitted on the wall to the left of the door, can't be seen on pic.
£10: End Feeds
£68: TOTAL
