Posted this on another forum so apologies if seen before, Had a hob fitted by a Gas safe fitter 2 months ago, I ran most of the pipe work, he connected the hob and supply end. He done a tightness test and the work was fine, I was very happy with his work until, I was putting up the the outside Christmas decks and bent down near the semi concealed gas meter box on the floor, And got a whiff of gas, I opened the box and the smell was really noticeable, I have some leak spray so I sprayed the joints and the test nipple which bubbled away like a good un, I turned of the emergency valve and called National grid, the guy came from the Grid he said it was one full turn from falling off!
I am really shocked at such a school boy error, should I raise complaint with Gas safe? Is this a major issue? we all cock up from time to time, also over a two month period how much gas was leaking? will it make a vast difference to my gas bill?
kind regards Tony
kind regards Tony
