You will find that you can turn the head in one direction and it will let water out and then "click".
Do that about 5-6 times and then leave it to settle down and it MIGHT solve the problem.
It could also make it worse but I fine that it will often clear the problem. If it does not then you are no worse off except that if its leaking more then it will need fixing sooner rather than later.
