Altec CPS 130-6 won't stop running
14 May 2008
Wiltshire
Hi there
a friend has just moved in to a house where there has been a new central heating system installed. There is an Altec circulating pump next to the hot water cylinder upstairs. The pump runs even though the programmer is not set to heating or water. It stops running only when I turn off the programmer at the electrical spur switch. There are 2x three way valves fitted in the vicinity.
Is this a faulty Pump, Valve or Programmer? They all seem very new if not brand new
Thank you for any help.
Stuart
Hi Pete thank you for your reply. Not 100% sure they're 3 way but definitely 2 motorised valves.
Best
Stuart
