Are consumer 13A sockets double-pole switched ?
JM2
14 Nov 2010
Retired in:- Nottinghamshire
Kind of thought they were single pole (L) but now informed all uk sockets inc. domestic are DP switched.
Curiosity value only. Are they ?
AIUI there is no requirement for double pole switching in the standards, some brands do it anyway others don't.
Even if known to be double pole and have the contact gap required for isolation I would be very reluctant to rely on a socket or FCU switch for safety isolation since it has no provision for lockout and very little resistance to accidental operation.
In relation to an FCU, I would agree with you - unless, perhaps, the FCU was very close to where I was working (but, even then, there is the risk of accidental operation, particularly given that they are "down=on" switches).
However, I don't see any issue in relation to sockets (whether DP or otherwise)- to achieve pretty foolproof isolation, one pulls the plug out :)
Kind Regards, John
not all switched sockets are DP switched.
I understand that switched sockets cannot be used for boilers for this reason. Either unswitched socket so the plug has to be withdrawn (so guaranteeing all poles isolation) or a FCU. FCUs are DP switched.
I have come across cheap and nasty (and quite probably non-compliant with BS despite being marked BS) FCU's with SP switching.
Nightmare when they are wired up RP.
As far as I'm aware the only sockets that are 2 pole switched are those specifically designed to use in touring caravans.
This has become over-complicated
Both wrong.
No.
There are single pole switched sockets and double pole switched sockets...
and then there are those in my picture.
There is actually no need for a switch on any socket.
All 7 brands of 'white' 13A sockets currently listed on TLCs website (BG, Contactum, Crabtree, MK, "Pure Range", Telco & "Ultimate Range") claim to have DP switches. In the case of Crabtree, there appears to also be a SP alternative available, but for all the other makes, one seems to have no choice but to have DP.
I find it difficult to believe that all sockets bought from TLC are being used in (or were "specifically designed to use in") touring caravans :)
Kind Regards, John
Socket-outlets are eminently suitable for isolation, if you pull the plug out and put it in a locked enclosure!
You missed the important part!
I don't doubt that you will think of some 'exceptions which prove the rule' but, in general, leads with plugs on are usually sufficiently short that the person working on whatever it is connected to will be so much in control over what happens to the plug that 'the important part' probably is not all that important :)
[On reflection, I suppose that there are situations in which one wishes to isolate for reasons other than that one is working on the connected equipment, in which case I admit that your 'important part' (or maybe even removing the plug!) could become important]
Kind Regards, John
Marbo sockets have a SP version.
