PULSE said:
Thanks for that is it ok just to connect the transformer up to the exsisting light rose and just use the same switch
Yup. You ought to check that the lighting circuit itself won't be overloaded by the new addition, but that isn't affected by where you connect it, and if there are 10 lamps in the set I doubt if each one is very bright.
One tip - make sure you can get at the transformer easily, because it won't be long before you have to replace it. And keep a stock of spare bulbs, as you might find that if one goes the remaining ones get overloaded.
and as for the L.E.D lights you are right it is a transformer plug but i have checked and it says ideal for zone 1,2 and 3 in the bathroom.
Ideal, that is, apart from the fact that you can't actually plug it in
. They really shouldn't be allowed to make such items, and as for the buyer at B&Q who decided to stock them doesn't that just show how incompetent they are, and how little respect they have for their customers...
I think i will just run a cable through to the next room before i gyproc the wall and have a socket there to plug it into. Would that be ok.
It would be tacky, and would mean that you couldn't control the lights from the room where they are, and if ever the power supply went wrong you'd have a major job to replace it, but provided you ensure that the cable won't be damaged and won't overheat through being buried, then it'll be safe.
But unless you are dead-set on having these, I'd suggest you take them back to B&Q and ram them up the manager's **se.
maybe not ideal but must be better than having a socket in the bathroom and visible wires.
More than that - you aren't allowed a socket in the bathroom.
