- Joined
- 8 Mar 2010
- Messages
- 257
- Reaction score
- 0
- Country
Hi there,
I am in the latter second fix stages of a new build and have been getting some prices for laying vinyl in the bathroom. It's a timber frame house.
The build-up from the joists is; joists, 18mm flooring OSB, 30mm polystryene with spreader plates (UFH pipe run in this) and 18mm t&g water resistant Caber board as the final surface. The Caber is isloated from the walls with 10mm of foam insulation, as supplied by the UFH company. There are a few screws in the Caber to prevent vertical movement, going through the styrene into the OSB.
As far as I am concerned, the floor is flat, level and stable. The various vinyl people all want to put 6mm WBP over the Caber board, stapling it every few mm. Personally, I think this is unnecessary (and will make life complex regarding the bath side panel and the floor that it butts up to) so we are at a stand-off.
What is the opinion of forum members? I am prepared to accept that if not installed the vinyl company's way, there will be no guarantee.
rex
rex
