If you kept your boiler mostly condensing then you could save about 12% plus about 4-6% because the heat exchanger is more efficient on most condensing boilers.
BUT keeping the settings so that its condensing well usually means using weather compensation control and by NOT fiddling with it. Also having somehat over sized radiators.
