Baxi 80e flashing on 50 fault code for the fan tested fan and no power going to it so after doing all the tests in the fault finding chart changed the pcb and now the 60is flashing fault code for the pump anyone know what could be wrong
That could be pump but also low system pressure. The pump is easy to check as is the system pressure
Remove the large screw on pump front and check for rotation while protecting electrics from water damage.
Stop chucking parts at it and get a pro in to save further frustration.
