- Joined
- 4 Mar 2007
- Messages
- 30
- Reaction score
- 1
- Country
I had a new boiler fitted last January 2015. My previous boiler worked well, but 10 years later I decided an upgrade was necessary.
A short time later, I got the rumbling noise. It was as if there was a Bus or truck parked outside the house, more so only in one room. However, when this does start to happen, the boiler also gets notably noisier.
After the pump was replaced it looked like it had been fixed, but the noise returned. Through lots of different attempts to isolate the problem, it became apparent that simply draining the boiler & refilling it has the effect of curing the problem, but again after several days it returns or even sooner in the winter when the boiler is on for longer periods.
I have also noticed that when the noise is apparent, if somebody calls for water, the noise lessens.
One year later, the manufacturers scratching its head, and the easy way out, is to conclude that the problem is with my system, but only since the new boiler when in, and only after a few days of use.
logic says that because the system has been there 10 years (and its clean), and the issue is not apparent when the boiler is drained and refilled, it has to be something that is happening and building in the boiler when it is used.
I thought I’d start positing this, in the hope that somebody might shine some light on this annoying fault.
