Hi
Just replaced the brushes and because they were very worn, thought that was the problem - sadly not. On START, water sounds like it's rushing in. Then a few 'clicks' and 'whirrs' and more water noise. Some water must be entering the machine because the Detergent Dispenser is sluiced - but that's about it. Thereafter, a few more 'clicks' etc but the drum does not turn to wash or rotate to spin. After about half an hour the END light comes on and the clothes are as dry and dirty as they went in. When the pump cap is unscrewed around half a litre of water (at the most) pours out. There's no fluff or other residue and the impeller is turning freely. Because of the brushes replacement I know the drive belt is correctly attached. I also checked the inline filters on the Inlet Hose - they were both clean. I'm stumped. Any ideas?
