Bosch WFF 2001 washing machine
13 Dec 2004
I have the washing machine above - and the on/off switch has suddenly stopped working correctly. I have to wedge the switch on with some cardboard. I've had a look an it seems the fascia is a sealed unit. Any suggestions on how I could go about fixing the problem? Thanks.
You need to remove the lid and then access to on/off switch is from behind. Easy to swap for new one just clicks into place.
I tried that before - but there is a metal casing - I can't see anyway to get to the button fromt that way....
Its not the button but the whole switch that needs removing.Look at the switch from inside and you see a small plastic tab at the top of it all you do is prise that away from the metal and slide the switch upwards.
