My Worcester boiler is in need of a service & repair, would it be recommended to get Bosch to come out and service/repair or should I find a competent local person? Will Bosch be vastly more expensive than a local independent service engineer.
Don't waste your money on repairing non efficient boilers buy a new high efficiency boiler with five years manufacturer's warranty. The Worcester Bosch engineer who replied hasn't got a brain and is wrongly advising you. Many manufacturer's are giving five years on there boilers and the boilers are very cheap nowadays.Think five years no money to spent on breakdowns. five hundred and fifty pounds for an ideal boiler and flue pipe you can't go wrong.
coomonsense....you have none...indeed you are a tit sir! please use this forum properley or go and climb back under your mushroom...you talk rubbish!
to the op if you say the model and problem you may be advised as to whether it is better to get worcester out. the £230 callout/fix is excellent but if its a £15 part it would be a waste!
Boilerdoktor your views are biased on this forum you are a worcester accredited installer also known as the thieves of worcester claiming to do better jobs than others but in reality not true, overcharging customers and providing service agreements for people who doesn't need them. You said in previous post that you've fitted hundreds of boilers and is worried about Worcester Bosch stealing your customers what a w-----r .Why did you replaced all those boilers when you could have repaired them?
