Box in a purlin
Status
Not open for further replies.
dkb
12 Feb 2009
Yorkshire
Hello
We’ve had a purlin supported with a new timber. As it’s bolted on it looks a mess with 8 bolts.
Can we box it in (plasterboard and plaster or some other means) or will it cause issues with breathability?
It’s on the inside of the house and the loft is converted.
dkb, good evening.
Can I inquire why is there no bolt fitted into the top hole?
Are the bolt fixings actually bolts or are they Coach bolts?
As for boxing in? I would use plasterboard, the thickness of the plasterboard will be dictated by the bolt head depth, meaning apply say 2 layers of plasterboard which will ensure a firm fix to the new purlin and with the 2 layers there will be no indication of the bolts being present, the botton layer can be cut around the bolt heads.
Ken.
the timber in the photo dont seem to be supportin anythin? how can it if the end is floatin free?
its been incorrectly bolted to what?
if the drilled holes are not slightly oversized then bolts in that formation in that position will possibly split the timber.
whats happening down the other end of the timber length?
dkb, good evening.
Ken.
They were part way through the work.
M16 8.8 high tensile bolts with 18mm holes drilled.
Thanks for the reply. I’ll look into doing that.
It can float and still offer support in the situation it’s been used for.
Nobody in their right mind would drill three large
holes in a line that close to the end of a piece of timber!
Status
