hi there i habe a brittony 80 combi. when the heating or water comes on there sounds like a gurgling coming from the pump area and the unit behind it any ideas guys?
no, can you see behind the pump there is a brass valve possible a small red cap, probably looks like its been leaking aswell, but this is designed to let air out. you could always loosen the screw on the front of the pump may release some air.
depends how bad it is, if the boilers working ok then if it is air it will most likely clear itself.
