- Joined
- 27 Jan 2008
- Messages
- 23,668
- Reaction score
- 2,667
- Location
- Llanfair Caereinion, Nr Welshpool
- Country
Years ago I built a Excel program to check the readings obtained after doing electrical tests and flag up faults. However times have moved on and I need to pay to have Excel on my phone so using Java Script means any device with a browser will do the calculation.
I have struggled was not as easy as I expected main problem was addition where is x = 1 and y = 1 then x + y = 11 rather than 2. OK got around that problem with eval but next is the printing.
This calculator does nearly what I want but what would add the cream to cake would be a print button where I can print the results minus all the info not normally given with a Schedule of test results and I just don't know where to start.
My attempts have gone full circle with.
Volt drop from Cable length Calculator
olt drop and Cable length from Prospective Short Circuit Current Calculator
Volt drop and Cable length from loop impedance Calculator
Each one slightly different and although close clearly there are errors I think from use of parseInt instead of eval in early versions.
Can anyone give me some pointers. One advantage of the Java Script calculator is I can ask others to test it with Excel it was so hard to find anyone who could test it and I know know I made an error with ring mains with Excel version corrected with Java Script version.
But maths is not my strong point I failed "A" level maths although I did manage to do it well enough to pass my Foundation Degree in Electrical and Electronic Engineering think the lectures took pity on me!
Logs and Calculus I and not too good at imaginary numbers I found easy and statistics is some form of magic and I really haven't a clue.
So trying a keep it simple silly approach any advice appreciated.
