gangman you must pick and choose your work, because its only possible to lay that many on the flanks,doing windows doors ect not possible to lay 1000+, reminds me of the asylum seekers here in london being payed less to run the line in while british guys building the corners on day rate thats a fact
[/quote]
If you read what I post you may of worked out I was talking working in the 80s.
Atoz is right in what he wrote, we had no cavity fill to worry about, and we had a 5hit hot labourers, actually my brother was the best. He's a C&G bricklayer but we earned more with him labouring.
As for doors and windows they did slow you down, only in so much as you had to put up a frame and set it level with a scaffold board. It was all wooden frames which were built in, no need to plumb the openings, just build to the line and butt up to the frame. All the frames had dactie so that was quicker.
Even you must know if you lay to a line it's faster than any level work.
You've obviously never used Blake's, with them you build one gable end then the other, the front and back is then all line work. There's no levelling bricks at all. The only plumbing was setting up the profiles, plumb and level the frames in place and just as a check on the openings now and again.
You may not have the attitude for fast bricklaying but don't think everybodies the same. We wanted to earn money so we did, and the best way was by hard graft and good organisation.
