Burning smell
Discussion in 'Electrics UK' started by boilerbeasty, 5 Dec 2010.
  1. boilerbeasty
    14 Jan 2004
    178
    Thanks Received:
    5
    Country:
    I noticed a burning smell from the supply and consumer unit under the stairs. I found that the black cable coming from the main fuse/supply to the meter was a bit warm, and its the fuse/connector bit that's warm. The red wire/connection isn't warm. The dishwasher was on at the time but nothing else to speak of.
    The meter was changed over about 18 months ago.
    When you flick the kettle on, you can often see the lights dim a tiny bit.
    Any ideas what can be causing this? I guess there's nothing I can really do as a novice but I'd like to know what might be going on.
    cheers...
  2. ricicle
    14 Sep 2006
    6,344
    Thanks Received:
    382
    Gloucestershire
    Country:
    It sounds like there is a loose/bad connection in the cut-out area - possibly the fuse contacts. This needs attending to by the DNO as soon as possible. Call their emergency number and tell them your concerns. In the meantime try not to use any high wattage appliances (shower, cooker, immersion, w/mc, dishwasher etc)
    • Thanks Thanks x 1
  3. boilerbeasty
    14 Jan 2004
    178
    Thanks Received:
    5
    Country:
    cheers for the advice, I will get them out asap
  4. sparkydude
    10 Aug 2004
    444
    Thanks Received:
    23
    Staffordshire
    Country:
    Have you called them yet ? I for one would suggest that if you have not done so, then do as ricicle has said, call their 24hr emergency number. A loose neutral with overheating especially on such a small load as a dishwasher could petentially catch fire , not trying to be over dramatic here, but you only need to look at a recent post of a burnt consumer unit to understand what a loose neutral is doing t the equipment.
    Let us know how you get on.
    Nick
  5. boilerbeasty
    14 Jan 2004
    178
    Thanks Received:
    5
    Country:
    Checked the forum after the kids were in bed, and got on the case. I called the emergency line, who immediately advised me to turn off the power at the consumer unit immediately. Southern Electric had someone around at the house 40 minutes later and they replaced the neutral block in the cut-out and its connection to the meter. The old block and that end of the cable were charred and had a bit of melted insulation.
    Full marks to Southern Electric for speed and professionalism....everything seems good now, the lights don't even dim when the kettle goes on.
    Cheers everyone for the clear and quick advise on this one...
Loading...
Share This Page
