Hello all,
I wasn't sure where to post as its not an electrical question as such, but as sparkers do a lot of cabling I'm hoping someone can help.
Here's a pic of the void space directly above our kitchen.
On the other side of the brick wall is the loft space of what was a garage (now utility room and play room)
I'm running around 15 FLAT ethernet cables (not as bulky as traditional cables) as far away from the electrical cables as I can and want to pass them through the red bricks. I plan to bracket the cables on left joist above the electrical cables.
What's best to do here? core through the red brick (as circled) or carefully make a big enough hole through the cement line (as circled)
There's already space directly next to the electrical cables (which isn't very clear) but I don't want to use this.
If its of any relevance, these electrical cables feed directly into the consumer unit (in a cupboard in the play room) on the other side of the wall.
Grateful for any advice. Thanks.
