I want to install downlighters into our spare bedroom.
It appears to me that essentially they are just a new fitting so theoretically I could remove the current one (standard white flex with bulb holder), draw the ceiling rose into the loft, then wire the new downlighters one to another from the live and neutral terminal on the rose.
I have no doubt that it will work fine, but will I be overloading the rose? Do I need to by a higher rated junction box instead? I plan to use 1mm2 2core cable??
Any advice would be gratefuly received!!
Many thanks
Drew
Many thanks
Drew
