can i still get this type of radiator?
18 Aug 2007
Cheshire
I want to replace a small singler panel radiator in my shower room. It's a little corroded and I thought I would replace at the same time as doing the room up. The original was the type with "ridges and valleys" and is 21" wide 27" high. It's been in since the late 80s.
My main limitation is that a shower cubicle door opens against it so I need it to be as close to the wall as possible. The ones I have seen in my local DIY and plumbers merchant seem to be quite bulky. B&Q stand off approx 82mm.
Height wise, it doesn't really matter, but say a 24" (600mm) wide would also be a problem.
I seem to remember that THORN from the 80's looked similar to this. Arte they still going? If so where can I get them. Otherwise, does anyone know another make that meets these sizes.
Rads come mainly in MM now so widths are 400 /500 /600
Heights 450/600/700.
Myson do odd sizes that match up to some of the old imperial sizes avialable on order from most merchants
I used to work for a radiator company. Google "West Radiators" and speak to them, they have there fingers in a lot of manufacturers and distributors, im sure they can help you.
is close for size
But the SC in the reference probably denotes Single Convector.
I think the OP is looking for a single panel rad without convectors due to size limitations re the shower door.
Ultraheat Compact 4 Single Convector rads stand off the wall 66mm or 77mm depending on which way round you fit the bracket.
Stelrad make an Elite P1 which is 500mm wide and 600mm high. Its output is 305 Watts. The current rad has an output of about 360 Watts, but the reduced output should not be noticed in a shower room.
