Certainly - here:Bigburn said:Can you point to where I have made an assumption that the OP has a cistern of sufficient capacity?
You've decided that this solution is better, without knowing about the existing resources. I made no such assumption, and advised on the basis of what I knew from the information given by the OP.You would be better off changing the mains over to gravity as well and use the pump as per design.
I don't quite see your point. Do you believe, for some reason, that adding a PRD would be harder and/or more expensive than providing a gravity cold service to the pump, even if there were an existing cistern of sufficient capacity?YOU on the other hand advised the use of a prv without even asking if the OP has a cistern.
OK, so you think it's important. If you feel that strongly about it then just ignore my opinions, but bear in mind that the OP is the one who needs convincing that you're right. Picking arguments with all and sundry is unlikely to achieve that.Its important if you want to give the correct advise which you dont seem to be capable of doing.
