Are you kidding? Are you serious? A PRV? ...I actually think you are serious?
And a equalisation valve compensates for any pressure imbalances as the shower is being used...like a toilet being flushed. A PRV does nothing like that.
Its pockets of gas arising inside a pump due to loss of suction head and may result in damage to the pump as the bubbles collapse.
If cavitation and loss of suction head does occur, it can sometimes be cured by increasing the pressure in the system, either by alteration of the layout to provide a greater hydrostatic pressure or a reduced pressure drop ion the suction line. Sometimes ,slightly closing the valve on the pump delivery or reducing the pump speed by a small amount may be effective.
That extract was taken from "Chemical Engineering " volume one courtesy of Proffessor J.M Coulson. Hope it makes it a bit clearer for you.
My earlier solution still stands. Take a separate feed from the cistern in the loft and you may need to change your cistern to 50 gallon capacity or alternatively change the float valve to a high capacity type if your mains flowrate is good thus allowing you to keep the existing cistern.
You could lash some 22mm plastic pipe in quite easily. Just follow the same route as the cold feed to your hot cylinder and then follow the route that the hot supply takes from the hot cylinder.
Most pump manufactureres also recommend siting the pump close to the base of the hot water cylinder also and I think this manufacturer also specify this .
The forum is littered with your personal sneers, so it's a bit late to get high and mighty. Or are you just trying to get your posts deleted, like last night?
