Ok. So I drive a 1997 Toyota Carina E Leanburn Sli. It's a 1.6 litre petrol engine car. It still drives great after doing 240k miles. It is so reliable that I don't want to part with it, but I also see little point in spending a lot of money on the car if and when it does need anything done.
The Car Test is booked for Tuesday 22nd May. ANd I am wondering what things I can do to give myself the best chance of passing.
1. I have checked all my lights. Hazzards/indicators are fine, as are the brake lights. Parking lights are gone by the looks of it, and one of my headlights seems to be acting weird. When the parking lights are switched on, it looks as though there is light coming through the headlight. Just a tiny dot of light? Might just be a reflection, but as far as I can see the 2 parking lights are gone. Also my rear lights are gone. So obviously, I'll replace the bulbs for parking lights and rear lights.
I have booked an oil change for the morning before the test. The spark plugs have done less than 10K and so should be fine. Air filter is probably ok, but I might change it anyway to be safe. Mainly because my IAC valve seems to get dirty regularly and it makes the car rev erratically. SO what I intend on doing is spraying Carb cleaner down the case of the air filter, through the straw, to get it as close to the IAC valve as possible. Hopefully that will make sure that it is clean. Put in a fresh air filter, get the oil change and give the car a 20 to 30 minute drive before the test. This should make emissions lower, right? Is there anything else people would suggest? Is there something I could add to the fuel? Once the emissions are good, and the IAC valve and air system is clean, fresh oil should get the car through without any problems. I am not aware of any other possible fails that my car could have as other than those things it seems to be running perfectly?
