- Joined
- 11 Jan 2004
- Messages
- 42,791
- Reaction score
- 2,647
- Country
Hi Folks
I have a wheezy old system that is costing me dear. I have just swapped from Npower to M&S energy on the advice of uswitch. Npower were charging me £221/ month for dual fuel on a 5 bed det.
It's an Ideal Mexico with 12 rads, basically gravity-fed but with a couple of valves under the floor (don't understand much about CH wiring....)
It dates back to about 1982.
I would like to install a Worcester system, but don't have a single clue where to start, save to say I have searched a few posts here and I know Combi's are rubbish if you want to open more than one tap at the same time.
Being a five bed, 2 bath 5 person household, with kids 14 and under, we use a lot of heating and HW.
In fact, the bathroom was refitted last year with a separate shower and sometimes the bath taps and shower are running together.
So, we need a boiler system that gives us lots of hot water!
I love the principle of a Combi where you ditch the tanks and cylinder and have limitless HW on demand, but they don't give multipoint use.
A system to replace what I have seems the way to go:
Greenstar FS 42CDi Regular
Although there is a "System" boiler they do that does away with the need for the storage tanks: I'm not au fait with this type of boiler.
My only worry is my water pressure. I'm not sure it's the best. I know Regular systems can work on low pressure, but if the 42CDi throws out 25lpm, it can only do that if the water is available on the incoming side.
Now, I know pressure and flow rate are related but are not the same.
However, without the aid of a pressure gauge that I can fit on my outside tap, I went to United Utilities website and they told me that my water pressure would be "poor" if I could not fill a 4.5 litre container in 30 seconds.
Well, it filled in 22.5 seconds, but does that tell me the pressure is good? I suspect it also varies too.
That flow rate equates to 13 litres a minute.
Do I need to get my supply looked at?
And, finally, given the age of my system, should I change the rads as well, or will a powerflush suffice?
Thanks guys.
Thanks guys.
