hunter to balance rads quick explanation,turn the boiler heating thermostat up to max and room stat.
now see which side of the rad gets got first this is your flow. the other side is your return get two clamp on thermostats if you have got a standard efficiency boiler then you want the flow to be 82 degrees,
now on the return you want 71 degrees 11 degrees difference ie rad losing 11 degrees,do this on all the radiators and you should have a balanced system, dont listen to some replies they dont appear to know their own profession
