Changing virgin master telephone socket
29 Aug 2007
Bournemouth
Hi everyone.
I am hoping for some advice on my virgin cable telephone wall plate. It is a master telephone socket which has two connectors: A and B. I would like to remove the socket and replace it with a euro-module. I have a PABX Master socket module, can anyone confirm this will work? I assume I will need to connect the wire from A to connection 2, and the wire from B to connection 5.
Many thanks in advance for any advice.
To interfere with the master sock is an offence and frowned up on by all and your provider. If you wish to go a head , change it with a NTE5 or ask Virgin for an upgrade to an NTE , but this will be expensive.
Hi everyone.
For polarity issues , connect A to 5 And B to 2
Master Sockets
Master sockets are used for wiring PABX extensions. There are actually two types - a normal master socket and a PABX master socket, but either will work on a PABX. The difference is that a normal master socket includes a surge suppresser, and is used where the pair of cables coming in to the socket are on the end of a long cable that can pick up the effects of lightening near by (this is not a foolproof protection against lightening).
source http://www.swindells.com/wiring.html
Which means the telephone and modems on the line may work after you change the master socket. They will also be at risk of being damaged when there is a lightning strike close ( within a couple of miles ) to the route from house to telephone exchange of your cable. A direct hit on the cable, exchange or house is not needed to damage equipment.
Also you will be breaking the terms and conditions of the contract you signed for telephone service. When discovered removal of your telephone service is possible
