Cheap dialer option ?
doubt it will work, i have no idea how much a speech dialer costs but would not buying one be cheaper?
also which galaxy have you got, as some of them can send txt messages
Why bodge that together when you can get a "proper" speech dialer for just a couple of pounds more?
While such a bodge is likely possible it may well be a pain to find where to inject your trigger signal. Also when you add on the cost of the relay, the enclosuse for the relay and the power supply it will probablly work out more exepensive than just buying a proper alarm dialler.
a little bit of googling found this supplier of a proper alarm dialer at a similar price to the product you linked
http://www.securitywarehouse.co.uk/catalog/index.php?main_page=product_info&products_id=679
Cheers plugwash..That one is cheap enough so ill get one of them. :D
Pyronix do a Vocaliser that has 4 alarm inputs and dials 4 phone numbers, you can also dial into it using mics supplied, It retails for around £130
Considering the thread is 2 years old - I bet he's already got one.
