A 13 amp plug in appliance can give you a maximum load of 3kW, whereas your 7 kW appliance gives you more than twice that - i.e more cooking rings, I would think.....it all depends what you want it for.
John
I am wondering if you actually notice when cooking the difference ie do the 7kw heat up quicker, get hotter etc ? Or do you not notice a difference when cooking - both I'm looking at have 4 rings
There will definitely be a difference in the ring maximum heat and cooking / warm up time......its similar to a 3kW electric kettle being replaced by one of those 750w camping jobbies - the water would boil, eventually!
Connection wise, your 7kW appliance needs to be connected to the consumer unit, via a cooker wall switch This is said to be hard wired. It won't come with a plug fitted, naturally as a plug can handle a maximum or 3kW (13 amps). The smaller appliance comes with its own plug, and can go straight into a convenient wall socket.
John
You must be aware of how much total current will be drawn by the hob and the oven - (you've only mentioned the hob so far).
This will determine the cable size and fusing needed. Personally I go for a separate feed for each appliance.
To calculate the current, divide the wattage of the appliance by the mains voltage (usually 240 / 250v)
3000W = 12 A
250v
Therefore, if the appliance is rated at 3000w, it consumes 12 amps of electricity. A 13 amp fuse is needed as thats the biggest fuse a normal plug can handle.
Ask in the electrical section for regulations, etc.
John
