I recently moved house and have misplaced the transformer for my pre lit Christmas tree. I bought a 240V to12V transformer and manually wired the lights to this. They have worked but they are very dim. What is the correct transformer I need?
Probably the wrong “transformer”..a pure transformer will provide an AC output. You may need DC.
If your lights are LED you may need a power supply that is compatible. How do you know you need 12v. I have a set of Xmas lights here and the power supply is 31volts!
