Hi all,
I've recently (3 weeks ago) bought a new house. It's a 1993 build, that had a conservatory extension a few years later, '97 I think.
Anyway, down one side of the house/conservatory, I've noticed that the paving slabs have sunked a little (perhaps about 2" at the 'deepest' point).
See photo's below. The wall on the left is the garden wall, on the other side is the pavement & public road. The wall on the right is the conservatory, and the side of the house.
Noticing this had been niggling at me a little, so today I cleared away all the rubbish that had been there for a closer looked. Quite concerned to find that, the conservatory has clearly dropped perhaps 4-5mm, as is evident by the photo's below....
(house on left, conservatory on right above)
above, notice the window cill inside and out
above, best angle I can get of the 'drop'. Note that by lifting some of the loose slabs, I can see that some ground has subsided beneath the slabs.
Suspecting that perhaps one of the drain pipes in the ground has collapsed, I've had a look under the drain cover you can see in the photos. There is no obvious damage (not even cracking) in there. Water is still flowing out from the main/kitchen pipe. But I haven't yet tested flow from the gutter downpipe you can see running down the wall.
To be honest I'm not sure what to do next. Do I get a specialist out to investigate, and wait for the bad news? Or do I repoint the brickwork, seal the inside and hope nothing worsens. I'll be relaying the paving down the side anyway.
I cant see any cracks anywhere in the main structure of the house. The mortgage surveyor (only a basic survey) didn't pick this up. The sellers said nothing, nor did estate agent. I can't image that the previous owner (lived in the house since new) did not notice.
What should I do? If the pipe from the gutter drain has collapsed, can I simply dig it out and replace? Do I risk the whole house coming down?
Really grateful for anyone's help, really quite worried right now. All of my eggs are in this basket as such.
Cheers,
Tom
Cheers,
Tom
