Basically i have picked up a new 35kw 200w very cheap. However my house is fairly big and we have a 210l megaflow fitted indirectly at the moment.
My plan is to use the cylinder as a HW buffer and use the coil for a solar installation next summer.
I forsee a problem of compatability. You can do what you want now for your DHW needs but you would not benefit sufficiently from solar if you have a tank full of hot water all day.
To maximise use of solar you need as much of the tank alocated to only solar heat, particularly spring and autumn.
What I doat home is have n unvented cylinder heated via the one coil by solar only. The output of this cyl is fed to a backward TMV (single check valves removed) the cold branch of the TMV is fed to the taps, the hot branch to the combi.
In this way when solar is below tmv temp. it is sent via the combi for a top up. When it is greater than tmv temp it goes direct to the taps. Should one wish to one could fit a convensionally piped second TMV at this point to prevent vulnerable people coming to harm. We don't have anyone at home who needs this protection, we have brought them up to learn about dangerously hot water using the sense of touch.
The extra energy gained from the sun is significant when you utilise even the low energies which can pre heat your water beforfe sending it to the combi.
A combi without a diaphragm has no isses with sub TMV temperature water.
the system is utterly simple and reliable, and very cheap compared to all the elaborate ways manufacturers invent to fleece us.
