... and the timing for all channels is in the boiler already. All you need then is the underfloor manifolds and pipework - no more controls whatsoever.
Mystery. n Just htought on i have recieved my invoice for the 200w vitodens. £836+ When i bouight it the rep said the WC was included with the boiler, however the invoice is for the boiler and a Vitotronic 200 HO1A WC CTRL £136.34+
Does that seem right? It is defo the new version with the new WC controler that pugs into the boiler (like the 222)
No, they are sold with the choice of the two different controllers as extras. However, if you were promised an inclusive price, then ask your agent. With discounts like those, you may get your sub mounting kit a bit cheaper. I gave you the part no and list price for the older model - if you have black controls on the boiler like on a 222/242, you will need to check the correct part no and price with your man.
Incidentally, the solar enabled 242 has weather comp as standard.
Bit of an update. Boiler is all in and running. Fantastic bit of kit. Had to increase slope to 1.8 which is a little higher than i would have liked but hey!!
cylinder is heated via the hws in about 10-12 mins so pretty impressive. I have sorted a control option out for the HWS circ pump as yet, but im thinking of using the solar controller which would then give me a timed option and also the ability to control the cylinder temp via an immersion probe. Still a couple of technical points to look into but i dont think it will be a prob.
With this setup and an e tender module, i should be able to add solar heating later-on via the coil and use the HWS to heat the cylinder as a back up if the cylinder isnt at say 35-40 deg by 4.30pm when we need HW the most.
