Be funny if this turns out to be a cold supply running into the hot supply and not s boiler fault at all.
I have just had a similar issue with my Vaillant Ecotec 28, 8 months old. Hot water was lukewarm, installers came out, referred to Vaillant. Vaillant came out, checked boiler, no issues - boiler is supplying roasting hot water, but the all the house taps were not supplying hot water... only lukewarm.
As Vaillant man was leaving he suggested checking the mixer valves on all the taps. Before he left he showed me the hot water outlet isolation on the boiler, which we turned off and tested the kitchen tap - out poured cold water with the mixer turned full hot!
He left.
I then turned the hot water isolation valve back on and turned the cold water isolation valve for the kitchen mixer tap off. Bingo, the hot water was now roasting hot all round the flat. So, faulty ceramic mixed cartridge in the tap to blame, nothing to do with the boiler. It amazes me that trained, qualified "engineers" are so poor at basic fault finding through a process of elimination. Diving straight for "power flushes" etc.
To test the temp difference, put your hand on the hot water outlet of the boiler, at the boiler (might need to google your model to find which that is) and see how hot it is. The, cpmare that to how hot your water is. If it's significant colder at the tap, you might have the same issue as I did?
How on earth flushing the heating system could affect the tap temp I have no idea, they are not the same system!!
