Okay the bottom nut has being tightened and so far no leak (hopefully it will stay that way however the outside overflow is dripping not to fast but constant.
Probably because when the pressure relief valve(overflow) has opened in the past it hasnt closed fully due to carp on the seating, best get a new one, and also as C M says, check the expansion vessels not boogered.
