After much prodding and poking around I have a culprit for my vehicle issues, I just have a few questions about common rail engines before I continue.
Firstly, are the injectors just a push fit? they look to be, if so, how likely is it that one will come out easily?
Second, I am aware that they need coding to an engine, but if I bought a used one from the same vehicle, would it require recoding, and would it need to be from the same cylinder as the one I am replacing?
The last diesel I pulled apart like this was a normal non turbo, non common rail astra,
