- Joined
- 11 Nov 2004
- Messages
- 19
- Reaction score
- 0
- Country
Hi. I have a strange problem with some recently installed PL9 compact flouro brick lights.
http://www.tlc-direct.co.uk/Products/GLBRICK.html
These have been installed in the inside wall in our conservatory. There are 6 in total wired in 1.5mm 3core cable total length 12m. When they are initially switched on they remain on for approx 45 seconds then they all go out at once. If the switch is turned off then on, they will all light up again and stay on until turned off. The power is supplied from a Switched FCU coming off the downstairs RCD protected ring main. The RCD doesn't trip or anything, just the lights will go out.
Any ideas what may be causing this.
Thanks,
Nic.....
Thanks,
Nic.....
